メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Z337 Bold Sound with Bluetooth(2018年発売)の修理ガイド、分解情報、およびトラブルシューティング。
Need help with potentiometer replacement
My Logitech Z337 speakers probably have a bad potentiometer due to which it makes scratching sound while moving the volume knob and sometimes no sound.
I need help with the compatibility of the replacement Pots. that I ordered online.
Here are some pics of the one on my speaker’s PCB:
画像
画像
画像
Replacement (specifications on top) :
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
how did you even open the knob?
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
Hi @ayan_4u ,
Presumably you measured the old pot (out of circuit) to know that it was a 2 x 100K pot, is this correct or was it printed somewhere on the pot itself (a part number perhaps, I couldn’t see one on it but not all angles were shown)?
I can't find the datasheet for the dual pot but perhaps if you place your Ohmmeter across pins 1 & 3 and 4 & 6 of the old pot (out of circuit i.e. remove it from the board) hopefully you should read 100K Ohms for each. Count from left to right as viewed in image #1 that you posted. If not what was the measurement as you may have got the wrong one?
Then if you place the meter across pins 1 & 2 and then 4 & 5 the resistance should alter as you wind the pot from minimum to maximum. If the old pot was noisy then the readings may jump all over as there is a high resistance connection between the wiper arm of the pot and the resistance track that it is moving across
If this is the case, try the same with the replacement pot and check if it measures the same, except for the faulty wiper connection creating measurement problems of course.
If so you can just mount it the same way as the old one.
This is assuming that they are wired as most usually are but it’s just what I would try anyway.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ayan Haldar さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 56
今までの合計 1,693
