Only LED #2 is lit?
Hi!
I’m working on a customer’s iMac 2019 for a no-power issue. She stated it was rarely used for the first year and a half she had it and just recently started using it for remote work. I can’t imagine that she could have done anything to it to cause an issue. She even had the original box, foam, dust cover, everything. One day, she went to turn it on, and nothing happened. No fans, no chime, just a bit of an initial whine from the PSU capacitors when it’s plugged in.
After checking the diagnostic LED’s on the logic board, *only* LED #2 is lit. LED 1 would indicate trickle power and LED 1 + LED 2 would indicate the system is on and receiving enough power. Never, though, have I only seen LED 2 on with LED 1 off. I checked the diagnostic guide for this iMac and nothing in the troubleshooting section says anything about an LED being on “out of sequence” of the prior prerequisite LED’s.
What I’ve tried so far:
- Different working power cable
- Different wall outlets (both at client’s location and mine)
- Checked power button cable
- PRAM battery OK @ 2.8V
- RTC clock reset (because why not, at this point.)
Any ideas?
4 件のコメント
any update on this? I also have the same issue and couldn't find anything regards LED 2 on
rafazpace さんによる 共有
I'm seeing the same issue with a 2019 27" iMac. LED 2 on while LED 1 off.
I've replaced the PSU, no luck. Did you have any luck diagnosing this?
Stefan Cristescu さんによる 共有
No luck so far Stefan, Seems to me it might be a SMC problem, which may cost a new logic board. :/
rafazpace さんによる 共有
Has there been any progress on this issue? I ' ve same iisue on a2115 retina 5k 2019 . Only led 2 is lit on mobo
Volkan AK さんによる 共有
