Top half of screen is dark
Top half of the screen keeps going dark, and have little bright shadow on the screen
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Mark, I have a Samsung UE50JU6800 that has just developed the same issue.
Whilst i dont have a definitive answer yet, i found a video from Shivamm Rane on youtube ( a search on Youtube will find it, unsure of iFixits rules on links ) that details replacing either the entire LED light strips or individual LEDs on Samsung TV’s that cause this issue. It will be a few weeks before i attempt my repair but hope this helps you on your way.
The replacement LED strips seems quite readily available on Ebay.
If i am successful in my repair will post a guide.
このアンサーは役に立ちましたか?
Was the repair successful?
U mnie jest na odwrót na dole jest ciemniejszy ekran
@szmondjabin in that case your bottom backlight strip has failed. Replacing it should fix that.
@szmondjabin w takim przypadku uszkodzony jest dolny pasek podświetlenia. Wymiana powinna rozwiązać problem.
過去 24時間: 0
過去 7 日: 5
過去 30 日: 30
今までの合計 1,163
