メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sony Cyber-shot DSC-HX9Vは、16.2メガピクセルの解像度を持つコンパクトデジタルカメラです。本体サイズは幅10.4cm×高さ5.8cm×奥行き3.3cmです。
location/ replacement of internal Li ION battery
My question is similar to others for different models of the Sony Cyber-Shot camera
the date/time need to be re inputted each time the main battery is removed/replaced.
I wish to be aware of the exact location of the battery as :after checking out the manual for different models the design is different .
making the disassembly and repair troublesome .
I have used your site for many repairs of apple phones and ipods but now I am in different territory.
Any help would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
ベストアンサー
Hi @videophile999 ,
Here’s an image showing the location of the backup battery Sony part #1-756-813-11 (supplier example only), taken from p.18 of the service manual for the camera
画像
(click on image to enlarge for better viewing)
The manual details how to dis-assemble the camera and it appears that the battery is soldered onto the MS-461 board. (Sony part #A-1818-410-A - I can’t find an image of the board which would help but once you have accessed it the battery would be quite obvious)
I only found a few supplier listings when using the part number to search online for the battery. You may have better luck.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Thanks for the assistance and the image .
Looks like almost a full disassembly
what a lucky guy I am .
Now to find a supplier of the battery
Again THANKS
さんによる
@videophile999
If you can't find one by using the "Sony part number" usually most batteries will have their type or model number stamped on the battery.
So if you can't find a suitable supplier it may be a case of having to access the battery first and seeing if there is a type number on it and then searching for that.
EDIT:
On a hunch I searched for 175681311 which is a number shown in the supplier linked above and came up with this so it looks like the number is about right to use for searching and there are a lot more suppliers shown when searching this way, rather than using the Sony part number
Your model is not listed in the Sears link above but the battery is used in a lot of Sony cameras it seems, so highly likely it is the one
Good luck
さんによる
Sister had a broken camera that had been driven over by her car .
Dismantled camera and removed battery .
Replaced it into my camera All fixed and working
And as per the ruling of the gods . I have a spare screw with nowhere to insert it
Thanks you jayeff
さんによる
@videophile999
It mightn't be a problem if the screw is from your sister's camera and not yours.
Cheers
さんによる
la batterie on la trouve ICI : https://fixpart.be/fr/produit/batterie-s...
さんによる
コメントを追加
From the service manual it looks as if it is clipped to the MS461 board, not soldered, and is not supplied with the board so must be available separately.
画像
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Hi @jonmay99328,
Looking at images of the battery online to me it looks like it has solder tags.
image 1
image 2
さんによる
Pity! My perfectly good camera needs this replaced too so i shall have to visit a sony shop.
さんによる
I see the Amazon listing for this battery says it weighs a kilo !
さんによる
Hi. I have dismantled two cameras. The battery is definitely soldered to the board. As to supply I was not able to find any suppliers here in Australia. I suspect that is was a "one off" that was made specifically for this camera, but in the U.S.A you may have better luck. Even if I could obtain a battery from the "states" the shipping/postage is so high as to render the project nonviable..
Good luck
さんによる
@videophile999
Check if there's a battery model number on the battery itself and search for that number battery.
Sometimes if you can't find it using the device manufacturer's part number, using the battery model number will find it.
Just a thought.
さんによる
コメントを追加
I am not sure if this will be helpful for some but I found this on a Sony archive.
The battery can be found by looking for MS614SE. Have not tried it yet but seems to be the same one shown in the manual.
画像
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
on la trouve egalement ici : https://fixpart.be/fr/produit/batterie-s...
さんによる
コメントを追加
Hey, I’ve run into that same issue on a couple of Sony Cyber-Shot models. The internal Li-Ion battery (or capacitor, depending on the model) that retains date/time settings can be a real pain — especially since Sony doesn’t clearly document its exact location across all models.
Since you’ve done repairs before and used sites like iFixit, you might feel comfortable diving in — but yeah, layout and battery placement can vary quite a bit. In some models, it’s hidden near the logic board or underneath the main battery slot, which makes disassembly tricky.
I’ve had luck sourcing obscure replacement components from https://precisionzone.com. They mainly handle industrial electronics, but I’ve seen small format Li-Ion cells, capacitors, and support parts in their catalog — plus they do diagnostics and component-level repair services, which could be useful if you don’t want to risk going in blind.
Might be worth reaching out with your model number to see if they can help with a part or at least guide you.
Good luck — hope you get your Cyber-Shot back in action!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Allan Mason さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 27
過去 30 日: 102
今までの合計 4,270
