How to replace battery
この質問は役に立ちましたか?
On many of the newer Dell laptops, you have to remove the bottom cover. Dell usually uses ~4 screws to secure the battery. Once you remove all of the screws that hold the pack in, disconnect it and replace it.
Refer to this manual (online edition) to remove the battery.
To show you how to do it on most of these new Dells, I tore apart a 7490 to give you an idea (yes, this IS one of the 2nd HD or big battery models). Sometimes sticking a guitar pick in a corner of your choice as leverage can he helpful as well. These are not my best photos - I take more care in guides; this is more to give you a starting point from someone who has dealt with these bottom clipped laptops in general enough to know a few tricks.
このアンサーは役に立ちましたか?
Hi buy a new battery pack of the same model Del 5000, remove the old battery pack and insert the new one.
このアンサーは役に立ちましたか?
Have battery, how do you open case to replace battery.
過去 24時間: 2
過去 7 日: 10
過去 30 日: 51
今までの合計 2,448
2 件のコメント
I operated my dell laptop on power only as the battery needed a replacement since a long time.
But now i cannot turn on my laptop, even in power connection.
Is it possible that the damaged battery caused a short circuit somewhere thus the laptop is inoperable?
Costas さんによる 共有
Hi @costas1440
Yes. You should have at least disconnected the defective battery, better still removed it and even better replaced it with a new one.
If you remove the battery the laptop MAY work with just the charger.
mike さんによる 共有
