メインコンテンツにスキップ
モデル番号 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7プロセッサ
New Ram and SSD Unusably slow
I own a repair shop I have a 21.5 inch late 2012 iMac is running so slow it times out installation of OS, and is jumpy during navigation of installation media. New Ram old ram same issue, new SSD old HDD same issue, new thermal paste same issue, any ideas are much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
10 件のコメント
Your system is in CPU Safe Mode, which the SMC logic lowered your systems CPU clocking and the fan is cranked up. Which is why your system is so slow and the jerky!
Restart the system and run the onboard diagnostics pressing the D key. Let us know what you got for errors.
Reference: Mac startup key combinations
さんによる
@danj
Error: 0x8000000000000003, Cannot Load 'EFI/Drivers/TestSupport.efi
Status: 0x00000003
さんによる
@danj Also it is connected to internet via ethernet so it should have connectivity. do I need to have a HDD with an OS installed connected to the Mac for this to work?
さんによる
@gizmowizards - Sorry I got busy this afternoon. Diagnostics does not use your OS.
At this point you'll need to run diagnostics again, this time press the Option key as well as the D key. to get into the Apple server diagnostics. Make sure you have your system wired via Ethernet to the internet. Did you get an error at this point?
さんによる
@danj Same Error
さんによる
5件以上のコメントを表示
コメントを追加
1 件の回答
ベストアンサー
I think the original problem was a bad HDD was causing a similar issue as the lagging and jumpiness, but after I installed the SSD I never reinstalled the LCD I only tested without it, so it seemed like it was the same issue but it was a sensor not plugged in.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Randy Northrup さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 222
