Intermittent crackling sound but speakers work
Replaced battery successfully two days ago. Now hearing an intermittent crackling static sound. The speakers are working fine.
Update (03/02/2021)
Finally got something to upload properly. I can also report the MBP is running hot when I am on a website.
Update (03/02/2021)
I skipped steps 6-46 when replacing the battery.
この質問は役に立ちましたか?
7 件のコメント
In a very quiet room can you capture the sound and post it here so we can hear it iFixitでの質問に画像を追加する方法
Dan さんによる
@danj I reset the fan control to default and no longer hear the noise. The fans are both running normally. If it acts up again, I will record the sound as best as I can and post it. Thanks for getting back to me.
Charles Gardner さんによる
@danj The noise has resumed. I recorded it as a Voice Memo but cannot upload it in an acceptable format. Any suggestions?
Can you locate what area of the machine the sound is coming from? The only physically moving component in this model is the fan.
Zach さんによる
@chasgardner - Can you convert it to what iFixit supports? Its not very long is it? If it is you'll need to trim it down.
Dan さんによる
2件以上のコメントを表示
