メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年10月に発売されたGoogleのスマートフォン、Pixel 4 XLの修理ガイドと分解情報。
Is the front face unlock serialized?
I was wondering if anyone has replaced the front camera/face unlock assembly? If so, is it serialized like the iPhones? Or can you replace it, and it still work?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I figured ifixit would point it out, if that were the case. However, from my research, I'm getting conflicting results. I think I'm just going to get two Pixels 4’s, and see what happens
さんによる
コメントを追加
3件の回答
最も参考になった回答
I repaired five pixel four XL that had a damaged motherboard and I put new ones from Aliexpress on them, one of them did work with their facial recognition but the rest didn't.
I exchanged the camera of the phone that worked with the rest of the phone and it worked on all of them but however if I put the other cameras they didn't work.
The conclusion I have come to is that there are some unlock modules that work with any phone but others can only be used with your factory plate.
I put some photos of the facial recognition module in case someone is useful. This module works with all the phones I have.
The error that comes out is registration not completed the certificate has expired
画像
画像
画像
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
At the end I bought new camera modules on Aliexpress, I replaced them and I work all theteléfonos.porsome reason the 4 camera modules are not working .
Conclusion, if the facial recognition does not work and gives that error message, the unlock camera must be replaced with a new one.
さんによる
コメントを追加
As far as I know it shouldn’t be locked to the phone. If not I’m sure iFixit would’ve pointed it out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I recently changed the front camera with the full assembly. Now face unlock shows certificate expired. Everything works except Thale face unlock. Did try to “learn” my face but shows that error so I can't even register my face
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pat Yakis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 680
