メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Breville Dual Boiler BES900 - BES900XLのデバイスページ。修理ガイドとトラブルシューティングを掲載しています。2018年発売。
How do I open the underside of the machine.
I’ve noticed ants coming in and out of a hole near where the water tray sits. I’ve been trying to get the bottom off the machine by removing every screw in sight, but the locking/unlocking wheel is the only thing stopping it from coming up. I can’t seem to take the wheel off, or loosen it up.
any help appreciated.
thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Hi,
Don’t know the answer but here’s a link to the parts for a BES900 that has two .pdf diagrams showing all the parts so perhaps they may give a clue as to how to remove the drip tray.
Hopefully this is of some help until a more definitive answer comes along.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Plug on the top surface of the knob(the one that lifts the roller up). It has a screw under it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
See comment below about screw under twistey knob under drainage tray. Think there's also screws in the rubber feet under the machine.
Also, If you need to get into the inside where all the boilers are, 2 screws are on the back, top they are special torx head but you can get them open with a hex. There is a third once the back upper cover comes off that gives you access to the lower part of the housing. One of these plates is attached with an earth cable, just eave it attached. Once you get the upper back panel off you may want to remove the top, this just lifts out from memory.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dan Casey さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 58
今までの合計 2,050
