メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Whirlpool WTW4816FW or the Maytag Centennial washer MVWC415EW2.
Making grinding noises on sensing
Yesterday put clothes in washer and pushed start and left the room. came back and hour later and it was on sensing still and making a grinding noise. there was water in the tub but nothing else was happening. I did a diagnostic test and it came back with sensing light, rinse, done lights on first and second was just the done light which i looked up and it gave me a code of f5e1. but why is it stuck on sensing and making those noises and it won’t do nothing else. none of the other actions would work. the drain and spin wouldn’t work either. had to manually get the water out of the tub. can someone help with this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
See if this video helps you:
https://producthelp.whirlpool.com/Laundr...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Carla Ford さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 48
今までの合計 3,847
