MacBook Pro Late 2013 Is My Screen Bad?
Laptop works with external display. Is this a bad panel or something that could possibly be fixed on motherboard?
Sadly your screen has failed. You likely sat something heavy on the lid or gave it a good bang along the edge. Here’s the guide MacBook Pro 13インチ Retina Display Late 2013 のディスプレイアセンブリの交換 The hard part will be sourcing a display as you’ll only find recycled parts and Apple did have a run of displays with bad anti-reflective coatings which makes finding a good one hard and expensive! Here’s one 13” MacBook Pro Display Assembly (L13/14), Apple P/N 661-8153
このアンサーは役に立ちましたか?
houfuly my response is good, in my opinion, I think it might be broken but you can try to disconnect the screen and connect it again after cleaning the port if that won’t work you might need a new LCD.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 30
