メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
313回答 すべてを表示
Battery charges and is seen by OSX but will not power MacBook A1466
I have two computers that are identical model and year A1466 2014.
One is a client’s and the other is my personal. I used a part on my personal to diagnose an issue on the clients machine, turns out it was just a damaged keyboard cable.
Now upon putting my MacBook air back together the battery will not power the machine. OS-X recognizes the battery and can charge it but as soon as the plug is pulled the computer shuts off. It won’t turn on, on battery power either.
I have swapped batteries and same problem. Both batteries work fine in the other MacBook. The other battery will not power my MacBook. I have tried SMC and PRAM resets multiple times.
I have examined the port where the battery plugs in on the logic board and there is no damage. I have checked the voltage in several places on the logic board and it is giving me the proper reading in all areas.
It was working absolutely fine before and I have dissembled this MacBook several times with no issues.
Any thoughts or advice would be appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I would check the Keyboard cable which is connected into the trackpad MacBook Air 13インチ Early 2014トラックパッドの交換 I would also try swapping out the trackpad as well.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Unfortunately that had no effect
さんによる
You replaced the trackpad?
さんによる
コメントを追加
回答を追加する
Cody V さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 42
