CL error code L G front load dryer
CL code stays on. Stands for child lock but my model does not have a button on the panel
Hi @shawn03 ,
Activating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. The Control Lock icon will be shown in the display and all controls will be disabled except the Power button.
Deactivating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. Once set, Control Lock remains active until it is manually deactivated. Control Lock must be turned off to run another cycle.
Clean Filter Reminder:
The display will show Clean Filter when the dryer is turned on as a reminder to clean the filter. It turns off
when the Start/Pause button is pressed..
このアンサーは役に立ちましたか?
Thank you for your two suggestions on how to turn off the CL feature on my
LG dryer. I was just about ready to pull out, what little hair that I have left.
過去 24時間: 0
過去 7 日: 4
過去 30 日: 43
今までの合計 13,527
2 件のコメント
My model number is dlex3700v
Shawna さんによる
The clean filter light is on but the code cl is showing
Shawna さんによる
