メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ryobi Cordless Brad Nailer P320 (2016) は、木工や建設作業向けに設計された多用途なツールです。コードレスで動作し、Ryobi の One+ システムに対応しているため、幅広い用途で活用できます。打ち込み深さ調整や Airstrike テクノロジーなどの機能を備え、便利で信頼性の高い性能を発揮します。トラブルシューティングやメンテナンスの方法も充実しており、長期間にわたって使用できます。
How is this part not available?
My nailer took a tumble down the stairs and broke the metal bracket that the “no mar contact tip” attaches to (part of the depth set mechanism and the piece that sticks the furthest away from the body of the tool.) I've searched all the parts websites and it seems every o-ring and screw and other part is available, but I cant find this one and can't even find a good name for it. Not willing to buy a new tool over a $5 part. Can anyone help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I also have the same problem, the tip broke off. Can I buy the assembly which includes this part?
Steve
claretsfan@gmail.com
さんによる
コメントを追加
4件の回答
最も参考になった回答
Do you see the part on this diagram?
画像
If so, this site should help identify it and may offer it for sale
It appears that that is part of the magazine assembly.
画像
画像
https://www.ereplacementparts.com/ryobi-...
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Thanks Issac, but no, it's not a numbered part on that diagram /website. It’s the metal piece that screw 36 goes into after piece 35.
さんによる
@anonnimity Updated answer. Looks like it's part of an assembly, not sold as separate.
さんによる
Ryobi OEM 79007001084 Nailer Driver Assembly R213BNA R150FSA R213BNE
さんによる
It's called a "Work Contact Element" but part #79007001084 for the P320 does not fit on the assembly. Part 1084 has the same holes and fits on but it's a solid piece of metal. The one that broke on mine (Same as above) has metal grooves down the body and the width of the contact element isn't wide enough to slide over the nail tray. I've not found a replacement part the same as what broke.
さんによる
The piece you are looking for is not marked and I'm having the same issue! it goes through 35 and is the piece that you attach the no mar pad to! Drop your tool and it breaks off. At this point I'm so disappointed that I am now in the process of replacing my Ryobi tools! Never by Ryobi they are junk!
さんによる
1以上のコメントを表示
コメントを追加
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It sounds like the specific part you're referring to is the metal bracket that houses the "no mar contact tip" and is integral to the depth set mechanism of your Ryobi Cordless Brad Nailer P320 (2016). Unfortunately, without a specific part number or a clear description, finding this part can be challenging.
One suggestion is to reach out directly to Ryobi customer support. They may be able to provide assistance in identifying the part and possibly ordering a replacement for you.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Mine was Part 42 here: https://ryobipower.ordertree.com/model?m...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
sorry, was for trhe P321...
さんによる
コメントを追加
回答を追加する
anonnimity さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 50
今までの合計 2,497
