メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ドアおよび窓の修理・分解ガイド。
How to adjust uPVC window door?
I moved to this new flat, and there seem to be an air leak from the balcony window, the leak only goes from the side where the hinges are! is there anyway to tighten the door so it could be sealed, i must mention that the rubber seals are brand new and the main issue here is that the window is not adjusted right, only problem is how to make that adjustment?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
How to slowly window 2 side lock problems?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
hi @sureno ,
This link may be of some help.
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
the door seems to have a butt hinge type, now I am not sure if I am able to adjust the compression from the hinge's side, but if I do adjust the one from the lock side will that tighten the seal for all sides of the window? or will it only compresses it from the lock side alone!?
さんによる
@sureno
It may be a case of trial an error to see if you can get it right as there isn't too much adjustment in a butt hinge.
Here's another link that may help a bit more
さんによる
Alright, appreciate the input. I will do try that, I am trying to get the theory right first, in order not to screw anything up as the windows are newly installed :). thanks a lot for your help @jayeff !
さんによる
I will definitely try your link. I will let you know if this one work. Thank you!
さんによる
@sureno
if they were newly installed by a professional company and not by you, call them back to fix it as it wasn't done correctly if there is a gap that allows a draft through
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Sureño さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 488
