メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
AirPods Maxワイヤレスノイズキャンセリングヘッドホンの修理および分解情報。
Is the headband replaceable?
Apple has anticipated replacing the ear cups but I really wonder about the head band. There doesn’t appear to be removable and seems like it will wear out rather quickly.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
The headband is replaceable but the quote was $299 because they run wires through it. My netting wore out but I won't be paying that much just to replace that.
さんによる 共有
コメントを追加
6件の回答
ベストアンサー
There’s a pin hole you can stick something like a SIM ejector tool into that will “eject” the headband. It feels replaceable.
このアンサーは役に立ちましたか?
スコア 8
3 件のコメント:
I've looked closely but I can't see any pin hole. Do you have to fully retract the head band or something? Any hints on where to find it?
さんによる 共有
Remove the cushion, fold the headphones flat, and then there is a tiny hole centered at the top of the plastic where the cushion was. I circled it on this teardown photo: https://imgur.com/a/zJ8DiLa
さんによる 共有
Some time has passed since the question has been answered, we now know for sure that it is replacable. You have to press a small pin in the pinholes - for example the sim ejector tool of an iphone - and the headband will come off the speakers. Currently Apple seems to be the only source for replacement parts, though.
さんによる 共有
コメントを追加
Is there any third party headband I can use? Apple doesn’t provide this spare part.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I’ve checked with Apple Genius Bar and unfortunately Apple is currently unable to offer replacement headbands.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
There's a vendor, JoesGE, who repairs these and also sells just the replacement headbands for $180-240 depending on color and condition, but the parts are out of stock at the moment (10/24).
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
All of their products are designed with forced obsolescence and as little reparability as possible in mind. And their whole line of Airpods are no exception.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
That doesn't really answer the question.
さんによる 共有
@Zachary Whitley have you ever had an apple product serviced by apple? Call them up and ask if the head band is replaceable. They are the manufacturer after all so they should know what's best.
さんによる 共有
Just exactly THIS AirPods is different from the other ones. Would you mind reading the teardown? Its surprisingly interesting how these headphones are done!
さんによる 共有
These AirPods are very repairable.
さんによる 共有
コメントを追加
It's absolutely insane that the replacement is 200 euros + . Are there any other options?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Zachary Whitley さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 82
今までの合計 10,403
