メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
デバイスの修理に必要なスキルについて学びます。
Which iFixit Tool-set? What alternative?
Subject: Which iFixit Tool-set? What alternative?
I recently tried to replace my Mac mini 2014 HDD to an SSD…. the problem was that I did not have a Torx 5 bit…. I thought I would invest in a somewhat comprehensive set like the Pro Tech Toolkit or Manta kit…. I guess one downside is that the bit swap concept is more bulky and more cumbersome than dedicated tools for each bit… I think I like the case for the Pro Tech better…. I think Manta as some longer bits that are useful….. Also, I wonder if there is a reputable alternative to the iFixit Chinese tools…. any thoughts?
Oh, I just broke the screen on my iPhone 6s….. so I might need some tools for that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Here’s a kit to use for most repairs including the iPhone 6
Pro Tech Toolkit
https://amzn.to/37ow346
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions.の画像
製品
Pro Tech Toolkit
$79.95
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Each guide offers a listing of the needed tools for the given task. Review them to help understand what you’ll need.
Someone who is a weekend fixer will likely find the Pro Tech Toolkit is a good choice as it will cover a good 90% of what you’ll need for small device repairs.
A person who focuses on fixing MacBook system will often get discreet handle drivers as they are constantly using the same tool over and over again.
I personally have both the iFixit Pro Tech Toolkit so when I travel I have what I need. When I’m home I often use my fixed handle drivers similar to the iFixit Marlin Screwdriver Set - 15 Precision Screwdrivers
Your use case can be different from me! So you need to figure it out what works for you.
製品
Pro Tech Toolkit
$79.95
Phillips, Torx, Torx Security, iPhone Standoff, Tri-point, Pentalobe, and Flathead screwdrivers packed inside a fabric tool roll for compact storage.の画像
製品
$54.95
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Mac Fun さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 43
今までの合計 5,339
