メインコンテンツにスキップ
モデル番号はA1708/EMC 3164。2017年6月発売。このエントリーレベルのMacBook Proには伝統的なFunction Keyが搭載されています(OLED Touch Barの反対)。
563回答 すべてを表示
My display is glitching, vertical bars with horizontal glitch lines.
Hi there iFixers,
I have this problem with my MacBook where my display is showing some weird stuf to the point where the actual content is almost invisible. Here is a video of what I mean.
I tried hooking it up to an external monitor and it works perfectly fine on the other screen. I already tried resetting te NVRAM and all that kind of stuff but with no success.
As for the background story; I bought this MacBook of a friend of mine who told me he plugged in the MacBook, and then heard a pop and saw a little bit of smoke. After this the MacBook didn’t turn on anymore. I looked into the MacBook and saw that C6481 was blown. I replaced it and after that when I turned on the MacBook saw this phenomena occurring.
Now I am wondering where did it go wrong, did I open the MacBook incorrectly and did I damage the screen? Did I damage the GPU by using to much heat? Where should I start to look? I don’t suspect it has something to do with the LCD screen because this looks like a different kind of glitch to me. Correct me if im wrong and try to nudge me into the right direction :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
C6481 is part of the audio circuit PPBUS_G3H_SPKRL very odd for it to go and kill the system to boot.
さんによる
コメントを追加
1 件の回答
ベストアンサー
I can’t see anything you did so far would have damaged the screen. Did you take the logic board fully out? Damaging something in the process.
At this point you clearly the internal display will need replacement as the T-CON board attached to the display is messed up, here’s the needed part:
And here’s the guide to put it in MacBook Pro 13インチ Function Keys 2017のスクリーンアセンブリの交換
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I already had this feeling. This T-CON board, is this attached to the LCD screen itself or is it attached to the assembly? In other words, is replacing the LCD only enough to fix this or do i need to replace te complete assembly?
さんによる
@tomasvdlaan - The T-CON is hardwired to the LCD panel as well as a few other elements within the lid. It is not replaceable on its own.
さんによる
コメントを追加
回答を追加する
Tomas van der Laan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 284
