How to replace battery in ideapad p500
この質問は役に立ちましたか?
Hi,
Here’s the hardware maintenance manual for the laptop, taken from this webpage.
Go to p.44 to view the necessary pre-requisite steps and then the procedure to remove / replace the battery.
On p.91 Item #4 you will find the part numbers for the batteries. Search online using the appropriate part number only in the search box of your browser to find suppliers of the part. Usually the part number can be found on the battery itself if you wish to verify which one it is.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 1,566
