メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP 10 2101 J6F00UAは、HPが販売する10インチディスプレイ搭載タブレットの一つです。
The tablet Fails to charge
Sometimes it will charge for a short time, then all of a sudden it stops charging.
Update (11/30/2020)
Different connector cables have been used to eliminate the possibility of a malfunctioning connector cable. Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi @jojorep ,
It may be a faulty battery (even rechargeable batteries have a lifespan) or perhaps a faulty or loose micro USB charge port.
Use a magnifying glass and a strong light to visually inspect the charge port for any obstructions that may be preventing a good electrical connection. If there is anything in there, do not use a metal pin to try and clear it. Use a vacuum cleaner instead, to try and clear it.
If the charge port appears to be OK, here’s the maintenance and service guide for the tablet.
Opening the tablet will allow you to check if the micro USB charge port is securely connected to the systemboard.
If it appears to be OK then go to p.16 to view the necessary pre-requisite steps and then the procedure to remove / replace the battery.
At the top of p.16 you’ll find the battery spare part number (784326-001). If you search online using the part number only you’ll get results for suppliers, although the few that I checked didn’t show a price for the battery.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Joseph さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 17
今までの合計 422
