MacBook 13 late 2008 run off the battery but only in SMC bypass mode
Hi all.
After almost two years sitting in a drawer I wanted to give new life to my old boy macbook 13 inch late 2008 (unibody) which served me almost 10 years while I was upgrading RAM (8gb), SSD and taking care of it.
Battery was completely flat (wasnt the original one) so I bought a new one. When I plugged the new one nothing happened.
When I plug the charger I dont see ANY light on the AC charger. I thought it was a problem of the DC, so I changed the piece but it wasnt.
Macbook starts perfectly if I force it to start off the AC charger.
Checked with a multimeter the voltage, I get 12.5 volts on the plate where battery charge from.
What I realised is the battery I bought was probably too weak, so I forced the macbook to boot on AC, then while powered on I connected the battery cable I saw the battery went from sending 10 volts to 12.56 (while AC charger on), but sending only 12.36 if the AC is off.
Macbook is working in SMC Bypass mode, even from the battery! (No AC connected, unplug battery, press power button for 10 secs, connect battery and keep pressing for other 10 secs). If I connect the AC charger I suppose the battery charges, but I dont know.
If I reset the SMC, it wont boot anymore from the battery. And the battery indicator (the small leds on the side of the macbook) will wave from left to right (which I understand it means no battery is installed).
I suppose its a board issue. What should I do?
Thank you
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
That should help us isolate the issue.
Dan さんによる
@danj Hi and thank you!
I added two images: one is Coconut Battery, as I told you before doesnt recognize the battery since im bypassing the SMC with force start. The second image is my system. I installed Catalina version of dosdude (which is a patched version of Catalina that works on older macbooks). Could this be related?
I doubt it, I still think could be a logic board problem (especially some problem with the SMC).
Rospicino さんによる
