メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年モデルのMac mini(AppleのM1チップ搭載)に関する修理ガイド、分解、トラブルシューティング情報。モデル番号A2348で識別できます。
Hard Drive and Memory Upgrade
Can the hard drive and memory be upgraded in the Mac Mini with the M1 chip?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 28
1件のコメント
Here’s a bit more detail including a link to a teardown video: https://www.macrumors.com/2020/11/18/app...
さんによる 共有
コメントを追加
6件の回答
最も参考になった回答
Nope! It is what you buy, no internal upgrades possible!
See for your self! Everything is soldered.
画像
このアンサーは役に立ちましたか?
スコア 30
4 件のコメント:
Soldered AND glued up, way to go Apple!
さんによる 共有
As an ex Apple aficiconado, I am sorry to see Apple choose this path. It was hard enough with the high prices, but this is the icing on the cake. Market share armageddon.
さんによる 共有
The 2012 mac mini was a marvel of engineering. Almost as if Apple said... "we can make a machine that will last forever" AND "you can modify it in all kinds of ways- you've got choices."
Last 5-10 years has been the dark ages of Apple products tho'. Do they do any kind of design reviews on their boards in the post-Jobs era? I really wonder about that... their products seem like 'amateur hour'
Thank you for showing us that photo. Helped me decide not to buy- my kid can run Linux instead.
さんによる 共有
There's a video on YouTube by Luke Miani; Upgrading an M1 Mac mini SSD from 256GB to 2TB. Only for the brave ones, you have to know what you're doing.
さんによる 共有
コメントを追加
As the trend goes with Apple products, all “smart” parts are serial-paired and possibly encrypted. Swapping original parts may not work, not to mention trying to replace it with aftermarket parts.
Upgrading storage on iPhones are possible, but involves high-skill soldering and pre-programming. Could be the same story for M1 Macs, but I usually don’t have high hopes for this.
このアンサーは役に立ちましたか?
スコア 6
コメントを追加
This is a picture of decaying capitalism, money, money, money and in return nothing, greed
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I wouldn't call it "nothing in return". For quite reasonable money, you get a lot of quiet performance. What to complain about?
I have the Late 2012 quad-core i7 version of the Mini and know how great those machines keep working thru the years.
Bought recently the M1 equivalent and couldn't be happier. With Thunderbolt connections you can easily live with it - even if you do a lot of video work - as I do.
さんによる 共有
Apple didn't hide the fact that you cant do any more upgrades.
さんによる 共有
コメントを追加
The first Mac Minis allowed a CPU upgrade (if you were brave enough) as well as RAM, disk and optical drive. Obviously you could only put in what the motherboard supported, but it was a step in the right direction. Even the 2012 model is okay, I've got mine up to 16GB RAM and two hard drives totalling 1.5TB, the latter using the guides on this very site.
For me, the killer decision to not by an M1 Mac Mini, along with the non-upgradable disk and RAM (meaning I cannot buy the base model now and upgrade on the cheap in 6 months) is this : https://discussions.apple.com/thread/252...
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Did you open a bug report with Apple on Logic Pro? I'm sure the other M1 based systems suffer the same fate.
さんによる 共有
What Ritchie Swann said sounds like I wrote it! I mistook it for my writing! I have exactly the same experience and am probably going to move completely over to Linux instead of the M1.
Mostly because of the upgradability issues + as a result of what Louis Rossman has said (more or less) about Apple having learned to be incompetent at hardware design, since the 2012 timeframe, when they were still making really great machines (example 2012 Mac mini and 2008-2012 Mac Pro models, which are also excellent).
さんによる 共有
@danj A bug report has been filed with Apple because of that thread. As I've said elsewhere, I'm amazed that a new machine that has been heavily advertised as the best to work with has a crashing bug.
さんによる 共有
@Ritchie Swann - Did you second it? Or add your own report. The squeaky wheel gets the grease!
さんによる 共有
コメントを追加
Wow, looks like a Raspberry PI design ;)
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
@maltacode The principal difference is a Raspberry Pi is cheap and easily replaceable. If a Mac Mini cost $35 and the logic board could be accessed via four Phillips screws, nobody would complain about this.
さんによる 共有
@Ritchie Swann I was merely talking about the all-in-one design of motherboards, not comparing anything else, as that would be totally useless.
さんによる 共有
Well for $39 I guess the new Mac Mini would be worth the hassle.
さんによる 共有
コメントを追加
I replied yes on the question for upgrading the hard drive on the mac mini...i stand corrected. Ive got the A2348 and took it apart, no on the hard drive for me. Fan, memory, um, remove dust what be as far as I go. Laptops, yes and blindfolded:) okay maybe not blindfolded, friday humor-
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Which model is this? So yes you can upgrade ram?
さんによる 共有
@Leslee Langlands On the 2018 mac Mini model, yes. At least for RAM. On the 2020 M1 (which I believe is referenced here with the A2348 model number) and recently released M2 models, nope. Everything is soldered straight to the logic board.
さんによる 共有
コメントを追加
回答を追加する
Keith Wade さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 40
過去 30 日: 211
今までの合計 38,327
