Why is fan staying on after replacing hard drive mid 2010 Mac mini?
I replaced hard drive in mid 2010 Mac mini and now fan runs continuously and full speed? What is the fix?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like one of the thermal sensors was not reconnected. Check the two sensor connections as seen in Step 13 in this guide Mac mini Mid 2010 ハードドライブ
You may need to run the on board diagnostics if they appear connected. Restart your system, press the D key to enter.
Reference: Mac startup key combinations
If that doesn’t help you’ll need to give this great app a try TG Pro
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 57
