メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年9月20日に発売されたAppleのメインストリームiPhone 11は、6.1インチのLCDタッチスクリーン、デュアルカメラを搭載し、6色展開です。iPhone XRの後継機にあたります。
Screen jumping, glitching after installation
Replaced iPhone 11 screen but the screen is jumping and glitches after screen replacement. Had similar issue with the cracked screen so I don’t know if there was a previous issue not related to the screen. Anyone have a similar problem? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
I can’t say I’ve had this problem before but it could be that the replacement display is also faulty. Did you unplug the battery prior to removing and reconnecting the display? I would leave it turned on for a couple of hours and see if the problem goes away, it could just be static.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Yes, I unplugged the battery. I’ve had a similar issue and agree with you that it could be a faulty screen. I’ll reach out to the ifixit team for help since I purchased it from them
さんによる
Yes either a faulty screen or just some static, try leaving the phone turned on for a while and see if the problems carries on. If the problem continues then it sounds like a faulty digitiser.
さんによる
I’m having this issue rn but the screen works fine when not housed properly in its case jus freely sitting while connecting an everything works like a charm an as soon as I put it in properly it starts not workin to touch at all moving on its own an jus not what it’s supposed to do
さんによる
コメントを追加
回答を追加する
David Torres さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 20
今までの合計 1,573
