メインコンテンツにスキップ
Televisions made by the Chinese multinational electronics company, TCL.
270回答 すべてを表示
Why my screen no display but the light indicator was on
When i plug my 32inch tcl tv the power indication was light on but the screen was no display and when i put flash light on the monitor i saw the image but not clearly can you help me what was the possible problem and how much will it cost for the repairing?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
Fading TV screens point to a compromised backlight system. To troubleshoot this issue, some models enable you to “Picture Test” your TV. A “Picture Test” walks you through an on-screen questionnaire to help you determine if the issue is the source (the input, channel, or signal) or the TV hardware.
Or kindly check out another Ifixit thread of the same issue.
Why tv is on, volume works and can see a picture if you shine light on
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Display is not coming
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If you can see video on the screen with a flashlight, then you have a backlight problem. It could be the backlight voltage from the power supply, it could be a cable, or it could be the LEDs on the backlight strip.
Professional repair is always pricey. If you think you can DIY, see if you can find and download a service manual for your model. Then get a voltmeter, remove the back, find the backlight connector and measure the voltage. If none or low, disconnect the cable and measure it again on the PSU. If it is still the same, you have a problem on the PSU. If it is OK, you have an LED problem. PSU problems are likely bad solid state devices - Diodes, transistors, etc. It is easy (usually) to test diodes in circuit (the first suspect). Then transistors. Worst case, replace the whole PSU. Make sure it is the exact same part number as you have - OR it is specifically identified as an exact replacement part number.
Replacing the backlight LEDs is usually possible, but is more difficult.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cyber_marionette14 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 85
