Keeps throwing a code 2 to empty trash
Keeps saying to empty trash but there is no trash in it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Error 2 on an iRobot Roomba 980 usually means that the rubber brushes are clogged and need to be cleaned. The most likely cause is hair stuck on the brushes, which is preventing them from spinning properly.
To fix the error, you can try these steps:
If the Side Brush is not spinning after cleaning, you may need a replacement Side Brush Module.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 34
今までの合計 385
