メインコンテンツにスキップ
2014年4月のアップデートによりアップルの13インチMacBook Airはデュアルコアi5またはi7プロセッサーの更新とわずかなバッテリー性能の向上がされました。
313回答 すべてを表示
No input/output devices recognized
I've had this issue on and off. In the past, it has simply resolved itself randomly. Hoping to find a more permanent solution.
I am unable to use built-in speakers or microphone on my Mac, and when I go to system preferences>sound, no input or output devices appear listed. When I plug headphones into the headphone jack, the computer does not recognize these either. However, when I use Bluetooth headphones this does work.
I spoke with Apple on the phone and they had me reset Pram and try starting in safety mode. Finally stated up in diagnostic mode and got the error VFF001 as a hardware issue. They said I'd have to take it in to an apple store and spend probably hundreds on it, which is a lot for a nearly 7 yo computer.
Since then I've also tried reseting SMC, but no luck.
Heard this may be an I/O board issue. Any thoughts??
Thanks in advance
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It does sound like the Cirrus DAC which is part of the I/O board has failed or the I/O cable is bad.
I would first see if the I/O cable fixes things then go with the I/O board following this guide MacBook Air 13インチ Early 2014のI/Oボードの交換
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Amou さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 7
今までの合計 143
