メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP G72は、17.3インチの対角高精細ディスプレイ、スタイリッシュなデザイン、申し分ない特長を備えたノートパソコンです。手頃な価格のデスクトップ代替機としても適しています。
My bios is corrupted
my bios wont boot up with the key combination what do i do
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Which one system/laptop you are using, Must eloborate the model as well as. then might help you.
Cheers
さんによる
Hey J krug,
this would help you - https://support.hp.com/in-en/document/c0...
さんによる
コメントを追加
3件の回答
ベストアンサー
Try this steps given below-
Restart the computer.
Press and hold the CTRL + ESC key on the keyboard until the BIOS Recovery page appears.
On the BIOS Recovery screen, select Reset NVRAM (if available) and press the Enter key. Select Disabled and press the Enter key to save the current BIOS settings.
Select Recover BIOS and press the Enter key to start the recovery process.
The CTRL + ESC key combination can be used to trigger BIOS recovery on computers where an external keyboard is the primary input. This applies to Dell desktops, all-in-one computers, and laptops. The supported keyboard types on these devices are:
PS/2 keyboard
USB keyboard
Bluetooth keyboard - If BIOS has POST support for system-specific Bluetooth keyboard. Dell recommends using a USB keyboard for the BIOS recovery process.
Regards,
Rachel Gomez
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi Rachel,
But it is a HP G72 laptop - not a Dell???
HP recovery:
https://support.hp.com/in-en/document/is...
さんによる
コメントを追加
If the BIOS is corrupted, the system automatically attempts to restore the BIOS from a hidden partition when the computer is restarted. You may try your luck with the document below to restore the BIOS if the automatic BIOS restoration does not work.
https://support.hp.com/us-en/document/c0...
Alternatively, you might be able to fix the problem with corrupted BIOS simply by removing the motherboard battery. By removing the battery your BIOS will reset to default and hopefully you'll be able to fix the problem.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have changed my motherboard battery and I have the same problem now what do I do
さんによる
コメントを追加
Another solution from HP:
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
J Krug さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 37
今までの合計 7,089
