メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Keyboard and touchpad not working
Hi all,
I have opened my MacBook to clean the fan as it was overheating. When I’ve re-assembled it, the keyboard and touchpad didn’t work.
The backlight didn’t work either. The keyboard and touchpad of the MacBook seem to be dead. That said the power button still works fine.
Can you help me determine what the issue might be? Maybe I forgot to plug in something but it doesn’t seem to be the case.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
How did you go about cleaning your system?
さんによる
コメントを追加
2件の回答
ベストアンサー
I am fairly confident this is an issue with the trackpad flex cable. From your image I can see multiple pock marks and dents in the cable. They are known to go out easily on this model (they rub up against the bottom plate and degrade over time). When they go out both the trackpad and the keyboard become non-responsive. I would recommend replacing the cable and reinforcing with electrical tape. The trackpad cable is shown in Step 18 of this guide. You can purchase them online here.
MacBook Pro 13" Retina (Early 2015) Trackpad Cableの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks @zpl :) just placed an order for the cable. I will let you as soon as I replace it, if it has solved the issue
さんによる
Replaced the part today and resolved the issue. Thanks
さんによる
Glad to hear it!
さんによる
コメントを追加
最も参考になった回答
Hello Sir,
Apple does offer a free keyboard + Trackpad replacement for eligible models that have not come in contact with any kind of liquid. If I were you I would bring it to an Apple store to see if your model is eligible for the replacement. As to why the problem happened in the first place, I have no clue, my only suggestion would be to check with Apple for a replacement.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Might I note that the touchpad only comes free for models where the keyboard is fused to the frame, where apple just replaces the whole front panel
さんによる
Thanks for the feedback. I'm going to replace the trackpad flex cable like @zpl suggested first. If that does not work, I will resort to this option
さんによる
No problem! Good luck and have a nice day!
さんによる
コメントを追加
回答を追加する
Lenard Camilleri さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 113
