メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Ninja Mega Kitchen System BL770 is a complete kitchen appliance manufactured by SharkNinja.
Replacing broken plastic gears
Our Ninja BL700 stopped spinning. I disassebled the unit and the plastic 3 gear unit at the top had shredded teeth not allowing the unit to spin. Ninja does not offer a replacement part but saud I can purchase a replacement base. Does anyone know where I can purchase the part. An internet search has not been fruitful. Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
The person that answered your question isn't DIY savvy. You tore your unit down to find the 3 gear cluster inside the white casing. Apparently this is the main failure in the Ninja brand. I'm also trying to find a replacement, but you're the closest I've come to finding anything online.
さんによる
コメントを追加
1 件の回答
If you are talking about the gear-looking part on the drive shaft that meets with the bottom of the blade assembly, it is called a coupler or coupling. I haven't found one for Ninja, but there are a lot for kitchen aid and waring around. I would wonder if one of these is 'compatible'.
Example: https://www.ereplacementparts.com/coupli...
Update (10/17/2020)
Similar question: The flexable rubber coupler has broken..
In that, this guide is referenced which includes a rebuild of the planetary gear assembly. I see now this is what you really needed
https://sites.google.com/site/dgeake51/h...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
No. It is the gear unit that turns the coupler.
さんによる
Broken 3 gear unit that turns the coupler.
さんによる
さんによる
コメントを追加
回答を追加する
Tim Strickland さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 61
今までの合計 2,466
