メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
このページでは、2017年6月に発売されたHuawei Honor 9の修理ガイド、ヒント、およびテクニックを紹介します。
fingerprint button doesnt wwork after battery replace
Hello i replace my hono 9 battery like the guide on this topic
Huawei Honor 9のバッテリー交換
everything are good after i turned on my phone and battery works fine.
but the fingerprint button doesnt work. its completed dead.
thanks in advance
画像
i reopened the phone and did the same like battery replace.
i saw a small scratch as you can see in picture in the black flex cable.
do you think that is the reason home button doesnt work?
should i try to replace it? and where can i find a guide for it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
borbou-13-  double check your work. Check the ribbon cables that are routed underneath the battery. Make sure those are all still properly connected. Inspect the ribbon cables carefully for any tears. There is really no other reason as for why the “fingerprint button” won’t work any longer.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
i reopened the phone and did the same steps as battery replace.
check the edited post to see the picture of the cable. you think i need to change it? and is there any guide for it?
thanks
さんによる
I would since it is possible that this is the cause for it. there is no specific guide for that flex so you will have to find the best way using a variation of all of these Huawei Honor 9
さんによる
コメントを追加
How was your fix, did you managed to get this working again?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
i have already ordered the flex wire and waiting the delivery.
さんによる
コメントを追加
回答を追加する
borbou-13- さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 5
過去 30 日: 12
今までの合計 731
