メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
どこへ行くにも、迫力のサウンドを。SRS-XB10は持ち運びやすく、音楽に深みのある低音を加えます。
cracking sound from the speaker
cracking sound is coming in medium and high volume of speaker and when the speaker gives up bass
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Down speaker damage change a parts
=== Update (11/15/2020) ===
Hello bass speaker change
さんによる 共有
Where am i supposed to get the new bass diaphragm for replacement?
さんによる 共有
コメントを追加
3件の回答
最も参考になった回答
@kuleshwar could be a bad speaker coil or ripped speaker cone. You will have to take it apart and check the speaker separately. Of course there is always the chance that this is a bad amplifier (IC or circuit) again you won’t know until you check. Take a look on here for a teardown. After that post some good pictures of your pieces with your QUESTION so we can see what you see and possibly help you further.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
this happened to my sister it was just water damage
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same issue with my srs-xb10.
I’ve opened it just to found its actually the speaker itself having tear within its diaphragm. Sigh
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Hi i had the same problem that you, my speaker was cracked on my SRS-XB10. I tried fixing it with some Aleene’s Original Tacky Glue but it didn't work because there were many cracks and the speaker was just good for the trash.
I found one seller on Aliexpress that sells a 52mm speaker that looks almost exactly like the original Sony SRS-XB10 speaker and weights the same so probably the same Power. I ordered it, replaced the broken speaker with the new one (perfect fit) and it works like a charm, I didn't notice any major sound difference.
If you are interested the Aliexpress seller is "SOTAMIA Overseas Store" and search for "52mm 10W 4 Ohm Speaker"
https://www.aliexpress.com/item/10050031...
さんによる 共有
do you think this one work work
https://www.aliexpress.us/item/325680398...
kinda wanna go over board lol
さんによる 共有
コメントを追加
回答を追加する
kuleshwar さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 81
今までの合計 5,096
