メインコンテンツにスキップ
Mid 2010 Model A1278 / 2.4 もしくは 2.66 GHz Core 2 Duoプロセッサ
794回答 すべてを表示
Dim green MagSafe light and won’t boot, but boots with battery removed
I have a mid-2010 13” unibody that has had a dim green light problem for awhile but still charged the battery after a long time plugged in, and then ran normally. A few months ago the battery was getting frustratingly old so I replaced it.
Dim light/slow charge problem remained, but it worked.
A couple of weeks later it failed to boot after battery was left to completely discharge. Pressing the battery check button with MagSafe attached resulted in all lights flashing 5 times.
Replacing with the old/original battery doesn’t work. But pressing the battery check button just flashes the first battery light, not all 5.
Removing the battery completely allows the machine to boot (after pressing power button for 10 seconds). Machine then runs normally, albeit with fans at full blast and a little slower than normal. It also seems stable (eg I ran a full time machine backup).
Finally, I’m not an expert but upon inspection the D.C.-in/MagSafe adapter board looks like it might have some water damage. The logic board looks OK.
My options at this stage seem to be:
  1. Try another battery (seems unlikely to be this as neither work)
  2. Try another charger (I can’t find a spare one but could buy another)
  3. Replace the DC-in board. I feel like this is doable but given it’s a big procedure I don’t want to do it if the symptoms above suggest this isn’t where the problem lies.
Any advice appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Sounds like you have a damaged logic board. A dim green MagSafe charger LED is telling me the SMC logic is damaged. 90% of the time its caused by knockoff charger! What happens is when the battery ages the resistance changes so the battery takes longer to charge at a lower level but the knockoff’s don’t lower the voltage so the SMC logic comparator logic overheats burning out which then kills the MOSFET’s.
So you have a triple whammy here!
  • You need a new charger - Real Apple unit
  • You need a new battery!
  • Your logic board needs repairs!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Mbpneedafix さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 36
