メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年にHewlett-Packardから発売された低価格ノートパソコン。
Computer says no boot device found
im having a similar problem with my hp stream 11. the internal operating system was erased. now when i turn it on it says no boot device, i made the usb installer as suggested but when i plug it into my labtops usb still says not bootable disk enter bootable disk and press any key. i changed the bios setting followed the YouTube videos close as possible please what am i doing wrong cause rt now its and expensive paper weight.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Hi,
Did you make the USB "bootable" when you created the installer USB?
Did you press Esc quickly followed by F9 when starting the laptop to select the USB as the first boot option, not quite sure if this is what you meant when you said that you changed the BIOS setting presumably the boot order?
さんによる 共有
I'm running into the same situation, but my model is 11-r015wm. I used Rufus to flash a Windows 10 iso to a flash drive. I changed the bios settings to allow for legacy booting, and tried booting to the flash drive both with this turned on and off, and specifically using the bios boot menu to select a device to boot from. The bios doesn't see any flash drive I use. Idk if the issue is my flash drives are usb 3.0 and the only usb 2.0 I have is too small for a Windows 10 iso. I tried using a micro sd card but the laptop didn't recognize it either.
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Hi @Christian Sirolli
Don't know the laptop and the user guide doesn't show the BIOS menus but since the USB is not being detected at all in BIOS, check under the Advanced tab menu for Integrated Peripherals or Onboard devices or something similar to see if there is a USB Controller enable/disable option.
Some BIOS allowed for the USB to be turned off as a security measure
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sadly, there is no advanced tab. I've searched through each section and it is super basic. Downsides of having a budget laptop
さんによる 共有
@Christian Sirolli
Did you create the Windows ISO USB with UEFI support?
さんによる 共有
コメントを追加
回答を追加する
jayr5369 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 20
今までの合計 1,105
