メインコンテンツにスキップ
2.5GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.1GHz)、3MB共有三次キャッシュ
No WiFi or Bluetooth after replacing battery and speakers
I’m not sure where to begin looking for the problem. Can someone point me in the right direction? I have no Wi-Fi or Bluetooth after replacing the battery and speakers on my MacBook Pro 13 inch retina late 2012 laptop. I followed the tutorial exactly and did not seem to have any problems during the repair.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Either the I/O board cable or the I/O board its self has an issue
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board
Here’s the guide MacBook Pro 13" Retina Display Late 2012 I/O ボードの交換
Replace an I/O board compatible with the Late 2012 or Early 2013 MacBook Pro 13" Retina laptop. Fix problems with display, and data connections. Includes the USB, HDMI, and SDXC ports.の画像
製品
$34.99
Replace an I/O Board Cable compatible with the Late 2012 to Early 2013 MacBook Pro 13" Retina laptop. Fix the connection between the I/O Board and the Logic Board.の画像
製品
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I’m an amateur here so I really appreciate your time. I made sure all cables were reconnected properly. In your opinion should I proceed with replacement of the recommended items? I was extremely careful when I replaced the battery so I don’t think I damaged anything. Are there any other things I should check first? The only other ‘symptom’ before I replaced the battery was occasional difficulty getting the laptop to connect to a Bluetooth speaker. It would sometimes take multiple attempts to connect with no apparent cause. Thanks again.
さんによる
Try reseating the I/O cable, if that fails replace it and test again.
さんによる
Will do thanks!
さんによる
コメントを追加
I’m having this same issue. Did you solve it in the end?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@henrychugh26 - Did you try resetting the cable and if that didn’t help replace the cable. 40% of the time reseating fixes it and the other 40% replacing is needed. And lastly 20% the board is corroded up.
さんによる
コメントを追加
回答を追加する
Angela Desjardins さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 656
