Incoming Call Screen Duplicate
My incoming call screen shows then a second later another one pops that I can't access. Cleared permission on all apps and that helped for a few hours but it came back.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Try wiping the cache partition and check if that resolves the problem.
If still no good, try using the phone in safe mode and check if the problem is still there.
If not, then a downloaded app is the cause of the problem. You will need to uninstall each downloaded app, one by one and test the phone in normal mode, between each uninstall to see if the phone works OK. When it does the last downloaded app that was uninstalled was the culprit.
このアンサーは役に立ちましたか?
Thanks seems robokiller was the problem
過去 24時間: 0
過去 7 日: 5
過去 30 日: 24
今までの合計 394
2 件のコメント
Hi,
Is it always from the same number?
jayeff さんによる 共有
No all numbers
monte mason さんによる 共有
