メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsungの完全ワイヤレスイヤホン、Galaxy Buds+の修理・分解情報。2020年2月発表・発売。
Galaxy Earbuds Plus Battery Replacement
One of my earbuds isnt suddenly working, so I decided to open both of them to switch their batteries. Turns out, the battery of one of the earbuds isnt working anymore. i want to replace it but the batteries available here in ifixit is only for the galaxy earbuds. i need the plus one. Anyone here knows where i can buy one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
At 59 seconds into this video that battery type number for the Earbuds+ can be seen.
It’s a ICR1454S coin cell battery.
Searching online using the type number only gets results for an ICR1454 battery not the “1454S” .
I don’t know if they are the same or not but this Varta coin cell datasheet (see p.32) gives the specifications for the ICR1454 battery. There is no mention of the ICR1454S. Perhaps it is a later type.
Check what type number is printed on the battery that you have and search online using the battery type number only to see if there are any suppliers.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
The Verta Coin Cell should work fine. I am assuming the s just stands for the Samsung variant, because the under side of the battery in the Ear Buds has an edge coating which might act as an insulator or a guideline.
As long as the size, contact (+/-) areas, type (Lithium Ion), and voltage (3.7v) are the same the battery should work.
さんによる
コメントを追加
回答を追加する
Carl Jenry Chua さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 44
今までの合計 1,886
