メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for your Philips TV.
Why is "Channel up" on my TV remote jumping to channel 700 when press
Every time I press “channel up" it jumps to channel 700 (radio) regardless of what channel I start on. If I continue pressing it after that, it scans up as normal, until it reaches the first TV channel, and then it goes back to channel 70/ again. I have a 10 month old daughter, so I suspect she's pressed something on the remote. Everything else works fine.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Hi,
What is the model number of the TV?
さんによる
コメントを追加
4件の回答
ベストアンサー
Click ‘List’ (the button symbol is three horizontal lines, kind of like a cheeseburger symbol). Change the setting in the drop down from ‘Antenna Radio Channels’ to ‘All Satellite Channels’
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
So helpful, thank you!!
さんによる
コメントを追加
I found an answer, on my Mum's TV remote there is a language button, pressing it brings up the word English on the TV, pressing OK brings up a menu that defines the channels for the channel up and down buttons. Who knew that was there! It is very well hidden.
Once I found it fixing it was simple.
このアンサーは役に立ちましたか?
スコア 4
9 件のコメント:
I've been pulling my hair out for weeks and you've only gone and sorted it for me, I would never have found that, worked 1st time, thank you so much Mandy.
さんによる
It's a terrible design to put that menu item there, glad you are fixed now.
さんによる
Thanks, you have given me the answer too
さんによる
Glad you are fixed too.
さんによる
Thank you - one of life’s frustrations sorted 😎
さんによる
4件以上のコメントを表示
コメントを追加
Thanks this helped for my Sharp Aquos Smart android TV, I had the same. Whilst in a TV or radio channel press MTS > language displays e.g. English > press ok then hit < left or right > until you see “all channels” at the top of the panel.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
I have a Toshiba TV SUAZBe3DB and I have the same issue. Any tip please?
さんによる
I also have a toshiba and have the same issue, please help!
さんによる
I also have a Toshiba TV (only 2 months old) that's decided to do this, it's going through the window if I can't sort this, any help would be massively appreciated
さんによる
コメントを追加
Channel changers generally have a favorites position. It may be in that mode now.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David James さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 32
過去 30 日: 119
今までの合計 15,928
