メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル M8407 / 550 MHz または 667 MHz G4 プロセッサ
Question mark folder strange issue
I have a G4 titanium that has a strange issue. I have a working hard drive in it. When I put it into target disk mode, I can boot other systems off the hard drive. When I try to boot the machine itself it gives a question mark folder. I have system 9 and OS X tiger installed on it. When I press alt at startup it shows only the OS X install. Clicking on it just resets the boot selector. Same thing with 10.3 and a cd. What should I do? Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Reaching back through the cobwebs to the very back room of my brain, I find a pile of papers half faded and out of sorts with no order. So as I piece the sheets back in some as-semblance of order…
I think I remember Tiger offered dual boot within its self. No true dual partition so you could run older OS-9 apps within it. Some people also did a proper dual boot setup as well, that’s when you setup the drive with two partitions completely isolating the OS and app spaces.
So the fact you see only the one startup disk is not unexpected.
As for your question mark always showing up.
This is caused when the PRAM battery has died! I hope you like the game of finding Waldo as we have a bit of a hunt to find it!
Follow this guide to get the optical drive out of your system PowerBook G4 Titanium Onyx DVDドライブの交換 then pick up from Step 6 from this guide PowerBook G4 Titanium DVI PRAMバッテリーの交換. Lift the battery board fully out so you can get to the battery.
PowerBook G4 Titanium Onyx DVDドライブの画像
ガイド
難易度:
中レベル
PowerBook G4 Titanium DVI PRAMバッテリーの画像
ガイド
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I would never have thought to replace the replace the battery, Apple computers don’t make much sense! Thank you I will open it once more and replace the battery see how it goes. Thank you
さんによる 共有
@idintfixit - Don't forget to score & accept the answer if you're set!
さんによる 共有
its the next day, got a new battery and it actually worked! crazy! thank you!
さんによる 共有
コメントを追加
回答を追加する
Mihai Paun さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 22
今までの合計 596
