メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年初頭に発売されたCanon PowerShot SX530 HSは、Wi-Fi機能を搭載したスーパーズームカメラです。カメラの重量は1ポンド弱です。モデル番号pc2200で識別されます。
Problem with screen image through the lens
Hello, yesterday I was making the shooting, and while I was taking a picture with using the zoom, the picture on the screen through lense suddenly became very ruffle while shooting, with many bright strips, colors became distorted, an image turned into like on a very old TV with ripples. The pictures done look the same in the gallery plus when I turn on the camera I see the same effect on the screen through the lense. I was very gentle with my camera, I don’t know why It happened. Previousy the image was very clear like I look through the clear glasses. Please, If you know what to do, help me with this. Thank you in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Hi,
What happens if you take some pictures and download them to a computer and look at them there. Are they clear or also distorted?
さんによる 共有
@jayeff Hello, when I download them to the computer they are clear and normal
さんによる 共有
コメントを追加
1 件の回答
Hi,
It seems as though the camera’s LCD display either has a loose cable connection or it is faulty.
Here’s the ifixit Canon PowerShot SX530 HSのディスプレイの交換 guide.
This shows how to open the camera and check that the LCD flex cable connection to the motherboard is securely connected, (see image at Step.10). If it secure then as a DIY repair all you can do is to replace the LCD display and check if it now works OK, because if it is faulty it cannot be repaired, it has to be replaced.
Search online for Canon PowerShot SX530 HS Camera LCD Display Screen to find suppliers that suit you.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Nina Nikolayeva さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 514
