Ssd making me mad!HELP!
bought a new samsung ssd and did a clean install.also used trim to increase the read/write speeds.now there are two problems the hdd fan is always on full blast even though it has a external temp sensor.secondly the write speed seem to be very Good at 280MBps but read speeds are 150MBps.i also tried all types of trim method.pls help!!!!why is the read speed significantly low?
Refer to your other Q Ssd or the sata cable urgent help needed for the answer.
Dan さんによる
also do you have reasonable DRAM cache? As Dan says you cannot force speed increases when iMac has limits.
bmx2019 さんによる
