MacBookPro 2015 Keyboard backlight connector broken
MacbookPro 2015 Keyboard backlight connector broken while dissembling the logic board ,now it was not power on , please tell keyboard has to change in order to power on.
As you damaged the keyboard cable connection to the keyboard backlight you’ll need to replace the either the keyboard backlight assembly or the uppercase which is a lot easier!
Here’s the guide to get to either MacBook Pro 15" Retina Display Mid 2015上部ケースの置き換え
New Apple Macbook Pro 15" Retina A1398 Keyboard backlight 2012-- 2015+ Screws - US
Or Macbook Pro Retina 15" A1398 2015 Uppercase with keyboard - US You’ll need to transfer your trackpad over
In either you’ll need a new battery as well! MacBook Pro 15" Retina (Mid 2015) Battery as you’ll damage yours in the process!
このアンサーは役に立ちましたか?
i crushed my connector trying to plug it back in after reassembly - has anyone been able to bend back crushed connector terminals?
このアンサーは役に立ちましたか?
@owen1234321 - As easy as un-cracking a fresh egg!
Sorry guy you need to replace the damaged parts. How about posting some picks of the damage so we can aim you to whats needed iFixitでの質問に画像を追加する方法
過去 24時間: 2
過去 7 日: 15
過去 30 日: 67
今までの合計 4,401
5 件のコメント
Can you please post some pics of your cable and logic board so we can see the damage. Posting the guide picture doesn't help.
Dan さんによる
it,s broken in to two pieces
Rajeev さんによる
OK, still we need to see whats broken so we can guide you to what needs replacing. Do you need a new cable? Do you need a new logic board? Do you need a new keyboard?
Dan さんによる
@Dan the logic was not working already brought logic board EMC2910, from eBay ,while replacing the logic board the black light connector for keyboard was broken,it it affect the working for mac or working with broken connector.
Rajeev さんによる
So you ripped off the cable! Thats not the connector its self.
Sadly time for a new keyboard or uppercase
Dan さんによる
