メインコンテンツにスキップ
任天堂スイッチは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
Horizontal lines, and black screen with sound
Recently my Switches screen started acting up out of nowhere. When I power it on or wake it the screen is covered in multicolored horizontal lines with a sort of grid pattern, after about 1-3 seconds the screen will go black with backlighting still present. The digitizer seems to work perfectly as well, and the Switch functions normally when docked. This problem seems to have appeared out of the blue with no forewarning. It seems to have occurred in the span of about 5-10 minutes. I plugged my switch into the charger and left the room for a moment, upon returning the screen was completely covered in the aforementioned lines. I’m not sure if it’s an issue with the lcd or possibly an issue with the motherboard. I opened the switch up and there doesn’t seem to be any issue with the ribbon cables or connection. Any help would be very very much appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
I have same issue on my switch lite
さんによる
Hello did you solve your problem with the switch screen? I'm having the same issue with my switch lite and it came out if nowhere.
さんによる
Same just happened to me yesterday without me dropping it or anything happened out of the blue just like that
さんによる
I have this exact same problem, it came out of nowhere while someone was playing on it today. The screen also seems pixelated in some way, I'm gonna try to do something with the LCD flex cable.
さんによる
コメントを追加
4件の回答
ベストアンサー
I reseated the LCD flex cable for the display carefully and that seemed to fix the problem for me. It only occured when I unplugged the display cable from a previous repair.
If reseating the display connector does not help the display most likely needs to be replaced:
Nintendo Switchの液晶パネル(LCD)の交換
Nintendo Switch LCD
Replace a damaged or malfunctioning LCD display panel in a Nintendo Switch.の画像
製品
Nintendo Switch LCD
$49.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thanks for the advice I’ll give it a shot, not sure how the cable could have been dislodged, possibly overheating?
さんによる
The cable shouldn't go loose by itself as it is locked into place with a zif-flap connector. Worst case it would be the screen going faulty and needing to be replaced.
さんによる
コメントを追加
All i know, i lived in jamaica and my switch have lines, and i don't know how to fix it, All i gotta say is goodbye switch, my aunt gave me this nintendo from another country, bye nintendo, bye youtube, bye fortnite😞
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
my switch lite have that issue. when some ants get inside of my switch lite.i think the ants the to eat the ribbon. thats why im getting that issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This problem happened to me suddenly mid gaming and seems to get worse the warmer the console gets. I wonder how could this happen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Laurence Zeffler さん、ありがとうございました!
統計データ:
過去 24時間: 32
過去 7 日: 307
過去 30 日: 1,250
今までの合計 45,135
