メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
WiFi fluctuating between on and off
Earlier today, the WiFi connection on my MacBook Pro decided to randomly switch off and then switch on again on its own. I was on a skype call and in the background was running both the chrome and safari browsers. The WiFi connecting has been toggling back and forth every 2 seconds when ever the laptop is switched on. And it has been doing this for the past 8 hours.
It’s not a router issue cause other devices including another older MacBook Pro from mid 2009 is connecting fine.
A malware scan came back negative. Can someone please suggest how to go about finding out what’s causing this and how to go about fixing it? Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
If you think the issue is software related, I would recommend reinstalling the OS. It’s possible though, that this is due to a failing AirPort card. See this guide for replacement steps. If you have a kind friend or know somebody with the same model MacBook Pro, you can try installing their AirPort card to see if this resolves the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The AirPort board tends to fail hard, not sporadically.
The area I focus on in this series is the I/O cable connection which tends to breakdown. See if reseating the cable as well as the AirPort card helps other wise you’ll need to replace the I/O Data Cable
The other area I find is the antenna cables get damaged at the hinge area from all of the lid movement, which is a big job as you need to take the display fully off MacBook Pro 13" Retina Display Mid 2014のディスプレイアセンブリの交換 and here’s the needed part 13” MacBook Pro - Right Hinge, Antenna/iSight cable
MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cableの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
See iff the problem persists in Safe Mode.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chandrakant さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 44
