How do I fix my tracking issues?
I’m having trouble identifying the tracking issue with my headset. The base stations are wall mounted securely and are placed in the correct positions to be able to see each other and the devices in the playing area (All reflective surfaces have also been covered and the base stations are connected via sync cable). Despite this, the headset will have tracking issues and sometimes “Rubber-band” (I.E. :The head will phase into the floor or rocket to the ceiling, or just have general tracking issues at random). My best guess is that there is an issue with the sensor’s in the headset because the controllers haven’t had that issue nearly as frequently as the headset has, the other guess is that there is something wrong with one or both of the base stations themselves. Any ideas to help fix this?
1件のコメント
hi this is a common problem you can fix it using this guide
https://aiomobilestuff.com/htc-vive-trac...
Aio Mobile Stuff さんによる
