メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Viveは、HTCとValveが共同開発し、2016年4月に発売されたHTC初のバーチャルリアリティヘッドセットです。このデバイスのモデル番号はNM80PJT100です。
How do I fix my tracking issues?
I’m having trouble identifying the tracking issue with my headset. The base stations are wall mounted securely and are placed in the correct positions to be able to see each other and the devices in the playing area (All reflective surfaces have also been covered and the base stations are connected via sync cable). Despite this, the headset will have tracking issues and sometimes “Rubber-band” (I.E. :The head will phase into the floor or rocket to the ceiling, or just have general tracking issues at random). My best guess is that there is an issue with the sensor’s in the headset because the controllers haven’t had that issue nearly as frequently as the headset has, the other guess is that there is something wrong with one or both of the base stations themselves. Any ideas to help fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
hi this is a common problem you can fix it using this guide
https://aiomobilestuff.com/htc-vive-trac...
さんによる
コメントを追加
2件の回答
最も参考になった回答
How large is the tracking area roughly? I have had the same problem and it seems that it was due to it being too large. It could also be if they are mounted too high like to the ceiling.
This was with a Oculus rift CV1 so I’m not sure how the HTC Vive would do as I’ve only set that up in small spaces.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Its a small tracking area. Roughly about 9 feet long and 5 feet wide of an area. I only stand in the middle of it due to the space I have available.
さんによる
コメントを追加
Restart the Oculus Runtime Service .Reseat the Rift S cable .Swap PC USB-A ports .Disable USB power saving.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Duff さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 36
今までの合計 991
