メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
MacBook Air 13 A1466 - Failure LCD display (with photo)
Hello guys! I need your help!
My MacBook Air 13 have really few hours of work, maybe about 200H and 30 charges cycles. And now, when I turn it on, display have failure (check photo).
I’ve checked the issue with external monitor (hdmi), and works fine.
Please help, if it’s fixable, what should I check? I guess, it doesnt have inverter board…. or need buy new lcd replacement?
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Sorry your display is damaged. I’m suspecting you tend to use a spray cleaner on the screen give it a couple of deep sprays getting nice and wet! Letting the cleaner drip down. Sadly thats what did you in! The liquid got to the bottom edge into the circuity located there damaging it.
Please don’t spray the screen instead spray the clean micro cloth and use it to wipe the screen.
You might be able to fix your system but its a bit tricky! You’ll need to carefully lift the bezel around the screen to get tn the LVDS connector at the bottom of it to clean the build up of dried cleaner and the corrosion. You may need to replace the LVDS cable if its damaged. Otherwise you’ll need a new display assembly MacBook Air 13" (Mid 2013-2017) Display Assembly and here’s the guide to do it MacBook Air 13インチ Early 2015 ディスプレイアセンブリの交換
Replace a display compatible with the model A1466 Mid 2013 to 2017 MacBook Air 13" laptop. Includes the 1440 x 900 LCD 13.3" screen, aluminum case and camera. Part #661-7475, 661-02397, 661-02505.の画像
製品
$314.99
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
Hi Dan!
Thanks for your answer.
I didn’t used any spray or products on screen. Usually, I clean it with dry micro cloth.
You mean, it can be a simple LVDS connector?
さんによる
Corrosion within the displays connector and the cable.
Thats now a bit of a stretch given you are not using anything wet on the screen that dripped down into the circuitry. I think it's time for a new display.
さんによる
Alex, how did you fix that ?
My wife's macbook air 13" have almost the same problem as you. Low hours and very few battery cycles (71). No spillage or shocks...
Sometimes screen shows some clear images through the lines, sometimes flickering...
I bought a replacement screen (complete assembly), but only be able to work on it next month...
I'm very curious about your solution.
さんによる
Hi Fernando, fixed with full screen replacement...
さんによる
It's a confirmed Display issue you will need to get the full Display Panel Replaced...Check with local third party repair center
さんによる
コメントを追加
回答を追加する
Alex さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 73
今までの合計 693
