damaged battery in MacBook
Hello mates! I was cleaning my MacBook and found this “scratch” on my MacBook battery. I don’t know how long it does exist or maybe I just did it right now when I was opening everything but I wanted to ask you if it’s safe to use it this way or I need to run and replace it as soon as I can. There are no bumps or anything like that; the shape and size are perfect just to clarify.
この質問は役に立ちましたか?
1件のコメント
At this point don't charge your system as that could push it over the edge!
This is clearly a failed battery! It's nothing you did.
If you can download this app CoconutBattery take a snapshot of the main window and post it here for us to see iFixitでの質問に画像を追加する方法 Lets see if Apple should fix this for free!
Put the bottom cover back on making sure you don't leave any marks. I would make a call to Apple to log the issue. Just say you heard a small pop and smelled an off odor. Don't over volunteer information that you opened the system.
Keep the system away from anything flammable (on a tiled or metal table with nothing flammable near it)
And lastly, don't use it other than making a current TimeMachine backup on an external drive.
Dan さんによる
