メインコンテンツにスキップ
モデル番号A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duoプロセッサ
310回答 すべてを表示
SSD Upgrade with HDD Thermal Sensor
2009 21.5” iMac, SSD upgraded without HDD temperature sensor I’m using a fan control program to manage. Please guide this method can cause any issues in feature. OWC in-line sensors has using for 21.5” & 27” models, is there any alternate method other than OWC sensor for upgrading SSD’s for iMac 2008 to 2011?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There is a second option instead of replacing your hard drive, just add the SSD using the dual drive adapter as outlined here: iMac Intel 21.5インチ EMC 2308デュアルドライブのインストール If your HDD is still working this would be a great way to gain the speed of the SSD making it the boot drive and apps then leveraging the HDD for your data and other content.
Sadly, the way the systems thermal management works requires the sensor to be present to measure the drives heat for SMC. As the sensor is within the hard drive we need to replace it with what SMC expects. The OWC in-line sensor OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 Hard Drive Upgrade the 2011 unit is different unit!
Some people have tried using a spare optical drives sensor, it's not as good as the OWC sensor. When I was swapping out drives in this series I just found the OWC sensor was just easier.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rajeev さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 8
今までの合計 641
