メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ASUS Q536Fは2019年5月に発売されました。 日常使いからゲームまで対応できる、競合製品と比べても手頃な価格の2-in-1 PCです。
Back Pannel Won't Come Off
There is something holding my pack pannel on and I can't figure out how to take it off. From the outside it looks like a circle made of the same material as the panel. I can pry it open and look inside and it seems to be a screw. I can't move it as there is nowhere to place the screwdriver. It may be on the otherside underneath a keycap but from what it looks like it doesn't like up with any keys. Pressing down on it does nothing, I can't rotate the back pannel off either. Anyone know what this is and how to get it off?
画像
画像
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
Hi,
Did you look under the “feet” to see if there are any screws there, holding the cover on?
さんによる
I can pry the whole thing off, its just that part in the middle that is holding onto it.
さんによる
what screwdriver did you use to open the screws?
さんによる
Maybe the screw is under the keyboard. Take out keyboard and have a look.
さんによる
https://www.youtube.com/watch?v=WW30dcvq... this model should be the same frame. if it is holding in a obviously no bottom screw area you need to pop the plastic off from the top the keyboard and remove those screws to expose the screws that you need to get at
さんによる
コメントを追加
1 件の回答
ベストアンサー
This is most likely a cover hiding a screw in the middle of a back panel. You can use a very small flathead screwdriver (e.g. flathead 1) to pry off the screw cover and get access to the screw head.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Braxton Biggers さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 25
今までの合計 1,104
